seattleguy
Does anyone know why every other bill there is a 30 some second pause before it will take another bill?
I bet you're right. One hopper is always empty while the other is full. I bet it is a bad motor or something stuck in it. I will check tonight.once the validator accepts a bill, it is inhibited from accepting another bill until the rowe can refill the dump bucket. If you have a hopper that is jammed or has a quarter stuck in one of the hopper motors, then it takes about 30 sec for the rowe to refill the dump bucket. You should notice that the quarters are not getting lower in one of the hoppers.
The validator will almost surely display a code when it's not working, which will probably be disabled by system. It's a flashing red light, and the list of what the flashes mean is on the stacker.seattleguy said:No code displayed that I can tell.
If you expect help with your problem, you could try to be more knowledgeable about your own equipment or put forth the effort to help figure out what you have. You could have at least taken photos of the inside of the changer or given some sort of description of what's in it.seattleguy said:How do I figure out what kit?
