Magic Wand touch pad selectors
Lakeview
I have 20 year old Magic Wand touch pad selectors instead of rotoray. I found a used replacement but the spot free button turns on both spot free and high pressure pump. Are there programming instructions for Magic Wand touch pads?
Do you have the old style with the ribbon cable and black box or the new style with the relays built into the back of the touch pad? If it’s the new style, the buttons can be programmed. Unfortunately, I don’t remember how to do it. You could call Istobal on Monday (1-800-336-8795) and ask to speak with David Reed, he built a lot of those meters with the touch pads and may have some instructions on the programming saved on his computer. If it’s the old style, they are not programmable.
I have the new style. Will call Istabal as suggested.
thank you
