Macneil Wheel Boss Shaft
br549ms
Mississippi
Noticed the Wheel Boss brush drivers side looked like the shaft had a lot of end play, making noise. First thought was bearing, but after looking we found the hub was loose on the extruded aluminum shaft. After removing the pillow block bearing and the hub, we saw the damage to the shaft. We were able to cut the shaft about 1" and reinstall the hub. There was enough extension on the hub to slide it in the bearing and have full coverage in the bearing.
Have any of you done this? looks like the PS side is wearing also.
Any after market shafts for the Wheel Boss?
br549ms
Mississippi
Well I guess no one has had this issue. The fix is holding up well, with no issues. I am ordering a shaft for back up even though I am not a fan of the design. We will modify the PS side once the new shaft arrives. I will try to photo and document it this time.
NickL
Are they the newer style square shafts? I see a lot of problems with those.
br549ms
Mississippi
Looks like no upgrade, however I did find the extruded shaft material and purchased for less than 100 each. I will send the link to you tomorrow
br549ms
Mississippi
logo
Framing Technology Inc.
137 Syke Street
Rochester, NY 14611
Catalog #
DescriptionQtyShipping Method(s)Unit PriceAmount
45X45-H/6M45 x 45 Heavy
Length: 100in
Cut to Length:
11 via LTL - Freight -
CS10M12HEXCS10M12HEX11 via LTL - Freight -
TN101/4-20TN101/4-2011 via LTL - Freight -
You will have to cut to length, but is identical including screws and nuts
JMMUSTANG
car wash owner
at the car wash
Looking at installing a new Wheel Boss tire brush.
Do you guys like it?
Is there any others you like better?
