LW4000 virtual treadle options??
Indiana Wash
Indiana
OK, I still have treadles! I am losing some of my elderly customers because they cannot drive well enough to get on the treadles. Is there any option that is $5000 or less for a virtual treadle including installation? I really need something but I don't know what to do.
PEI
Danville, VA
I'm not aware of a Virtual Treadle Kit for less than $5,000, but you can change the treadle plate out to pressure pads with very little retrofit or cost. Remove the inside rollers of the treadle plate. Strip the treadle down to just the flat metal bottom plate. Replace the two proximity sensors with pressure pads. Leave the reflector strip in place. It doesn't create the nice clean floor of a virtual treadle, but makes it much easier for older drivers to get into place and at a fraction of the cost.
That said, because the drivers side is no longer a set point and this fix will not provide sizing for that side of the car, you may loose some cleaning capability. The loss of cleaning should only be slight though.
