raisetheprice
- Joined
- Sep 5, 2007
- Messages
- 252
- Reaction score
- 0
- Points
- 16
After 13 years, I'm divorcing the bent pipe bearing a top the arch index/swivel. No more seized bearings to bent pipes at our shop, swivel changes shouldnt take 1/2 your day with a bearing that's got to be cut off. Has anyone used/installed WW's block design retrofit kit to a 4000? My current bearing brackets are bolted and not welded like some, which should take it down a notch on the skill set required. It sounds like a fairly easy conversion for a few 100 bucks. Anyone?
