LW prox switch Cable, from K-R...?
Prox cables are pretty much all the same. I see kleenrite has a 5 meter cable part number IFMC001. You could probably get a cable from automation direct for less than half the cost.
Do you have the link to the 12mm eyeys from automation direct thanks
and the 30mm shorts
and have you ever purchased a gear box or motor for the 4000
Can you guys add some links? I usually get prox's and the cables from Kleenrite, they are much less expensive then the distributors, but still expensive. Also if someone else has gear box options for laser & washworld that would be great as I feel they are well overpriced.
