raisetheprice
- Joined
- Sep 5, 2007
- Messages
- 252
- Reaction score
- 0
- Points
- 16
Why is there a 1" brass check valve to the undercarriage out in the bay?
I get that...however there's not a check for the arch?...it drains out.you need checkvalve inline to prevent line from draining out during non usage. when pump kicks on if line is empty it will cause vibration and possibly damage line or pump.
Thank you I will find itI believe you can download them at PDQINC.COM
Thank you I have checked itriramire - please check your Private Messages on this forum for instructions on how to set up an operators account on our website.
Yes Newhampshiretech is right I will try to download from therenewhampshiretech is correct - you can download owner/operator manuals from PDQ's website - www.pdqinc.com - however, you'll need to sign up for an operator account to gain access to those manuals. You can also try contacting your local distributor for the manuals as they may be able to email them to you as a PDF. If you're unsure of who your distributor is, you can use the Find A Distributor link on our website to locate one in your area.
