LW 4000 Dump Vlv
Bud
NE Ohio
I just received a bill from my PDQ distributor for a repair kit for a dump valve!!!!!!!!!!! I know their prices are out of sight but this is really ridiculous. $155.00 I have heard of just plugging the dump valve, that it is not really needed. Has anyone ever tried this? Did it work ok? Thanks
You can plug the dump valve with no affect on the wash unless it is more than two bays away from the equipment room. The further away from the equipment room, the more time you will need to give the low pressure delay and high pressure delay to make up for the lack of dump valve. You can also just live with the arch not having changed over chemicals or rinses when it first starts across the front of the vehicle and not worry about the two delay timers.
No shipping. Tech had it on the truck while he was here for another problem. I checked with the parts dept. after I received the bill to make sure there wasn't a mistake. No mistake. $155.00 I really think PDQ is putting it to the operator, the people that keep them in business.
Bud I have many laser washes running, all with the stainless steel dump valve. We have found those to be the best ones by far. I know they are quite expensive and the repair kits are also expensive. But have found the only thing that goes wrong with them, is the stainless steel spring breaks. I was able to buy just the springs thru a local distributor http://www.normanequipment.com Hope this helps. Jon
