RockyMountain
Our tire & wheel cleaner is distributed with a pressure switch, electric motor, procon pump and expansion tank. We also have needle valves to adjust the air.
Issue: The procon pump would not build enough pressure to turn the pressure switch off.
Solution: Replaced the procon pump. Was talked into a fluid o tech.
New Issue: The pump works great, except when everything is turned off. The pump comes on and builds pressure. The pressure switch (brand new also) turns the motor off. The pressure drops and the pump comes back on. This happens over and over. I assumed there was a leak in a solenoids. Not the case. I have even plugged the output line before the check valve. There is absolutely no chemical going anywhere, yet the pump and pressure switch continue to cycle on and off. I assume the pressure is being lost either back through the pump or could it be a failing expansion tank? I checked the pressure on the tank and tried both increasing and decreasing it with no success. What should it be? More or less or the same as the chemical pressure?
I tried to attach a picture but the forum website and I weren't getting along.
Any advice would be much appreciated.
