Low pressure seals
yhannat
Hi Folks,
Did you ever have an issue with low pressure seal poping out after install. It for a cat pump 310 and all three of them keep doing it Previous owner had a retaining ring to keep it in place which is not recommended.
Are you putting the pump back together correctly? The seals are pretty much sandwiched in there. How exactly are they popping out?
They are held in place with the white plastic wick holders, not understanding how they are popping out? Are you leaking low pressure water between the pump and head?
Back in the day the low pressure seals were held in place by a snap ring on the brass seal case. They have replaced the older white plastic seal retainer with a longer white plastic retainer. What you need to do is buy new plastic seal retainers.
