I just purchased a 4 bay SS. Its my first one and trying to do my own service on equipment to know how everything operates. 3 of the bays run at 1000PSI (plan to increase) but have one that is at about 500. Was thinking first order would be a pump seal replacement, but is there something else to look at first? Do regulators go bad? If so, how do you know if pump or regulator causing low pressure? What else should i be checking?
Also, to increase the pressure, do you just tighten the brass fitting that comes out of the top of regulator?
Thanks for the help.
