Longest lasting boom swivels
RAAOO7
USA
I currently have been using fluid control 1/4 2000psi swivels. They last a decent amount of time before leaking. I've tried mosmatic which are worse and more expensive. Anyone know a better quality swivel which costs more but lasts a lot longer?
RAAOO7
USA
Those don't work good for me, they don't last.
By "boom swivel," do you mean the one at the center of the boom? I use the Adams brass high pressure swivel with a street elbow. I use the same swivel at the gun, no swivel at the top of the bay hose.
I used to use one at both ends of the bay hose, but I can't tell a difference if there are two or just one at the gun. If you use a swivel at the top of the bay hose, and if that's what you're calling a boom swivel, you should use a 1' hose off the boom with the swivel below that to take the sideways stress off the swivel so it will last longer.
RAAOO7
USA
I've thought about using a 1 or 2 ft whip hose and putting the swivel inline with the hose like you said. I haven't done it because I was thinking that's just another hose I have to change and more changes of leaks. Do the whip hoses on top of booms last pretty long? I use to put a hose guard on top and bottom so when customers pull on hose it doesn't bend so close to the end.
Twodose
NE Pennsylvania
SWM40032 < at the boom < mosmatic
SWM30654 < from the boom down to gun there is a 1ft of hose then this swivel, then 128 inch hose to gun. < mosmatic inline.
SW0260 < at the gun.
I get years out of the mosmatic swivels, the swo260 at the gun last the least amount of time.
Like mep I don't know which one your talking about in particular.
The whip hoses last a long time for me, probably through three bay hoses. I used to order hoses with a guard until I had a hose break under the guard. I watch for signs and try to change them before it breaks on a customer - a hose guard ruined my streak of 6 1/2 years without a broken high pressure hose.
RAAOO7
USA
how long do your hp hoses last ?
Those small 1' hoses are commonly called "swivel saver hoses" for a reason. My inline swivels last several years (maybe 5?)usually. The swivels at the t gun last maybe 1-2 years
RAAOO7
USA
Very interesting. I notice fluid control makes a 90degree boom swivel. What's the difference between there 90 degree swivel or if I use a female elbow and use a standard fluid control swivel?
Little to none, as long as it will work with your boom.
Car_Wash_Guy
out west
I use Mosmatic's at both ends of the HP hose. I just replace them with new when they start leaking - I don't bother rebuilding them.
Anybody else besides us who use the Hydrospray Z booms that are supposedly a tiny amount lighter duty than the Mosmatic? It is manufactured specifically it appear to be by Mosmatic. We bought the below slightly less cost but still very heavy duty Z Booms from KleenRite about 2012 or 2014ish.
Hydrospray B00240 or Mosmatic BOM65019
