Most Procon have an adjustment screw behind the little acorn nut that you can use to adjust pressure. I have Coleman SS unit and they have regulators on both the air and liquid side. When the liquid side goes bad I just remove them and adjust pressure through the procon. Be careful though, you do not want that screw to come all the way out. Theres a tiny spring behind it that will disappear, then you're screwed.
