led6 timer
The wiring is a little different even though the plug is the exact same, a couple wires have to be switched around, don't remember exactly which ones. Should be pretty easy if you are looking at both wiring diagrams at the same time
B&C’s Timemaster TM5, TM6, 1034 and Dixmor LED6 timers are interchangeable.
Pin 1 provides 24vAC hot to power an external coin counter
Pin 2 is the 24vAC HOT input from the coin acceptor
(Note: this is different from Dixmor’s LED7 which requires 24v COMMON from the coin acceptor)
Pin 3 is 24vDC- for the last-minute alert horn
Pin 4 is 24vDC+ for the horn
Pin 5 is Earth Ground
Pin 6 is Timed Output to the load (Rotary Switch or isolation relay coil)
Pin 7 is 24vDC for Auxiliary input for Bill acceptor
Pin 8 is 24vAC COMMON input for Credit Card readers
(Note: Timemaster’s Pin 7 & 8 are jumpered together and connect to nothing)
Pin 9 is 24vAC COMMON
Pin 10 is 24vAC HOT
Dixmor timers displaying “COIN” INDICATES A CONTINUOUS COIN PULSE COMING TO TIMER FROM THE COIN ACCEPTER OR A SHORTED COIN SIGNAL WIRE. DISCONNECT COIN SIGNAL WIRE AT TIMER TO VERIFY THIS PROBLEM.
