Led 5 problem
Mdbordelon318
I have a led 5 dixmor.. one of the setting buttons in the back is stuck or pressed it to hard.. But i want to get it fixed and get another one, but i dont see anymore led 5 dixmors for sale. .what is a direct replacement for a dixmor led 5 ?
I'm not familiar with the LED5, but the 3, 6, and 7 have a plastic cap on the switch that sometimes falls off. I use a ball point pen to set the timers, and when the cap falls off I can press and hold the pen retract to reach the button stem. You can also remove the screws, slide the timer out of the case and retrieve the cap to put it back on.
Mdbordelon318
I took it off and looked to see if i could reset it . but could not.. i may have messed it up worst..
CarWashBoy
USA
I would suggest to UPGRADE! Same time and Money!
The replacement for the LED-5 timer is the LED-6, it's just a little larger than the LED-5. You can send the LED-5 timer into Dixmor for repair.
