if memory serves me, the docking dryer as well as the stand alone both relied on the
door eyes to let the wash know when a drive off condition occurred. at the last pass of the wash, the mid limit flag does the handshake to start the dryer process by way of the dryer plc, if the docking dryer is set to driv thru it would start up, the drive forward sign comes on and it runs for the pre determined drive thru time setting, the wash would look for the car to leave the treadle or vt eyes then clear the t bar eyes at which point depending on the short bay or long bay setting it would attempt to do a start up check, or wait till the
door eyes clear to do so, either way when the exit
door eyes are blocked then un blocked if the dryer timer hadnt been used up but it saw unblocked exit
door eyes it would prematurely stop the dryer in a drive off assumption. now you don't have
doors but if you added eyes and wired them into the
door input x-45 and then set your option number for the machine having
doors. I think it would work without any changes needed.
"Typical
drying process
When the Laserwash® 4000 completes its last cycle around the car a signal is sent to the LaserdriTM by
the LasermindTM controller to start the
drying operation. The
drying time is programmed at the
LasermindTM keypad. The timer is started when the car leaves the car wash treadle to ensure the car
wash user receives the full programmed dry time.
When the LaserdriTM receives the operation signal the drivers side fan motor starts and subsequently the
passenger side fan starts along with the oscillation motor causing all three nozzles to direct air across the
car.
As the car moves through the dryer a photo eye centrally placed in the machine detects the roof and
after a one second time delay causes the damper to close restricting the air directed at the roof area.
When this eye detects the end of the roof there is a one second delay after which the damper will
reopen. The center nozzle articulation also works off this signal causing air be directed toward the rear
of the exiting vehicle.
This situation is maintained until either the dryer operation timer expires or the exit
door eyes determine
that the car has left the wash bay. Then, the dryer fans and the oscillation motor will turn off. This
completes the dryer cycle." they also used to offer a "dryer shut off kit" it was a set of
door eyes wired back to input x45
