Laserwash dryer installation??
cap732000
oklahoma
I am installing a laser dri on my laser wash question is do I need to run two conduits to dryers or just one and run my computer wire with my feed(power) wires?
koliver
PDQ Sales Engineer
DePere, WI
You should have 2 breakers supplying high voltage to the dryer. Do you know if you have a 30HP or 40HP dryer? That will dictate the size/load you have. You will also need a low voltage conduit ran to the dryer. Additionally there should be an air line ran too.
cap732000
oklahoma
Gotcha yeah there 30hp. So
I'm running 2-60amp breakers 6awg wire and I'll run a separate conduit for the low voltage from the computer. Is the way I'm understanding this. I saw the air hose what exactly does this operate& it needs to
Be at 60 psi?
