Jsobi
Is your Laserwash 4000 dumping weep at 50 degrees? Do you turn the laser off then on to fix this problem. I have an A5000 CPU version 21 that fixes the stuck temp probe issue. We have been running it a few years now. Works great. It will save on water and keep your tbars eyes from overheating. The original programmer Alvin made the fixes for me. I also had him fix the Goldline OS pulse, allows the laser to turn off a goldline after a fault. We also fixed when a TBar eye gets frozen, it cause a stuck in bay issue, without the weep turning back on. The Laser will freeze up in minutes, on that one. Let me know if you would like to purchase one. I can burn a chip for $100 each. I have Thousands into the project. Version 21 has all the features of version 20 with LaserMinder and the 3 bugs repaired.
Jon
Jon
