Prattaratt
I have a LaserWash 4000 that we replaced the low-pressure pump and check valves on, and ever since then, the soap, triple=-foam and Rain-X cycles have not had the same flow rate as when it was working before the pump went out. Would like to know if the pump we put in has the same capacity as the one we took out, as on the one we took out, the data plate was too corroded to read.
