We would need a little more information to give you what you may be looking for. What application are you wondering (LPA, 3X, etc.). The
CAT Pump is ran off the VFD for both low pressure and high pressure applications. The low pressure applications can run between 700-900 psi at the pump and the high pressure can be between 1100-1200 psi. Again, each application has it's own operating pressure range, and we would need to know specifically what you are looking for.
