Laser 4000 rollers
Mansfield ohio
Time to change the rollers on this machine the other machine has rollers that have greaseable shafts this one has bearings is this all there is to it or is there something missing
What I'm seeing is two bearings one on each side some sort of cap a washer a lock washer and a screw it's worked for years like this I'm just wondering if it's missing something.
These are the rollers for the gantry
Laser 4000. *** NO dryers have been removed years ago just the gantry dryers are no outside of bay.
Those are sealed bearings. The greaseable shaft rollers don't have bearings at all. The sealed bearings are zero maintenance.
Mansfield ohio
Thank you I understand that my question is is that all the pieces there is to it the bearing then the cap a washer a lock washer and the screw?
Just making sure I'm not missing a piece thank you
I don't know what pieces are needed, but I do know for certain that when it's all tightened down the bearings should not be in any kind of a bind.
PEI
Danville, VA
Provided there is a second bearing on the other end of the roller, then yes those are all the parts
