J jnot002 New member Joined Feb 10, 2024 Messages 2 Reaction score 0 Points 1 Feb 10, 2024 #1 Laser 360 says trolly system stop active. What can be causing this error?
Monte Member Joined Apr 30, 2020 Messages 88 Reaction score 47 Points 18 Feb 10, 2024 #2 Is the system stop relay lit on the bridge?? If the switches are all clear, but relay not powered...probably broken wire in cord to bridge
Z Zal Active member Joined Feb 10, 2019 Messages 195 Reaction score 82 Points 28 Location Illinois Feb 13, 2024 #3 If the stop is in the bay it probably has water intrusion. You can temporarily disconnect in the pump box. It should be labeled.
U Undertaker II New member Joined Apr 15, 2019 Messages 28 Reaction score 9 Points 3 Feb 14, 2024 #4 I had this happen a couple years back and ended up being a bad node board.
