Kleen Rite soaps advice
Question ... does anyone here purchase the 5 gallon kleen rite soaps, and then refull a larger drum?
I have my soaps as 15 gallon jugs, and use the 5-gallons to refill. However, I cannot seem to do it without spilling. I have tried to find a good screw on nozzle on Amazon, but even the one in the picture leaks.
Has anyone found a way to poor these jugs (even if the air hole opened) without getting it to spill?
They this drum funnel
We switched to what Earl said on most soaps, there are a couple we still mix. We stopped pouring and started using a pump like this. Way more convenient. We pump clean water through after we use and the pumps are lasting more than 1 year and going still.
So u r diluting the phonic wash product.?
Yes I dilute the JBS Fonic Wash PC-100 with 10 gallons of water in a 15 gallon drum. Then on my Hydrominder I have a Turtle wax dual tip metering block that I have Presoak on one side and Fonic on the other, on my Presoak I have foam brush going over to the dual tip metering block to give the Presoak a little bit of more Foam. I use the Fonic wash for both High Pressure and Foam brush. It works great.
