Istobal Flex 5 Lava flow
BlueDolphin
What does everyone put in their lava flow for the flex 5? We are having issues with too much soap going thru the lava flow. Who uses wax vs. Soap for lava flow?
I've found that if you put smaller injectors for the lava soap, you will still get a nice show and your consumption will go way down. What size injectors are on there now?
Carwash_Guru
Bristol, TN
10gpm injectors? I've had quite a bit of luck with the 5.5gpm, and reducing pressure on the pump to increase flow to lava arch.
