MEP001 said:New pictures after adding a reflector to the fixture with four 42W CF bulbs. Same bay, left is from front, right is from rear. One light is a brand-new 250W bulb and ballast kit, the other is the CFL's.
If I could have found a single, affordable bulb that produced enough light to make the retrofit, my opinion would be very different, but as it is I put over $100 into one fixture. For another $20 (plus bulbs) I could have just replaced it.2Biz said:Maybe what you tried didn't work to your liking, but my bulbs are still working fine after 2 years. Not a single failure...
I was trying to accomplish the same thing. Actually the light from the two working bulbs is still impressive, almost as bright as any of the two-year-old 320W MH, and now at a quarter of the wattage.2Biz said:It was to look for a quality conversion using our current fixtures that put out better light and was cheaper to operate than MH's
It's really not ok. Normally I'd be replacing the bulbs and ballasts about now because they're so weak.2Biz said:You might be ok with 80w of CFL light.
I'm sure they weren't. It even says on them not to use in an enclosed fixture, but it's a big fixture and it barely got warm to the touch with all four working.2Biz said:I doubt the 40w bulbs you used were manufactured and tested to be used in a (4) bulb enclosed fixture.
I called yesterday to reorder more 85W CFL's and they're back ordered to the end of February. I also ordered 12 105 CFL's and I will play with them but they certainly won't fit in our bay fixtures, but will try them in a few misc fixtures that I have. Bummer I'm going to need at least 100 of the 85's and my daughter is chomping at the bit to get started (as am I!)
Kevin, not sure by your post but I think you are trying to get from mogul bases to medium bases. If so then you can simply buy and adapter that will screw into the mogul base and convert it to a medium base bulb.
Kevin,
Does your mogul bases have two screws in the top that attach it to the aluminum bracket that screws to the fixture? If it does, you can use these holes to attach the medium base. My medium bases have two screw holes in the top. I think I was able to use one hole in the bracket and drill the other to line up with my medium base, but it was easy to drill since the bracket was aluminum....
Here is the ones I bought. Click on additional images to see the view with the 2 screw holes...
http://www.1000bulbs.com/product/3812/SOCK-L70045.html
Sounds good - isn't that about what they're rated for?2Biz said:My lights stay on an average of 16 hours a day. So far the bulbs have been on roughly 12,640 hours.
They didn't last long at all. One of the remaining two failed about a month ago, the other evidently couldn't handle coming on after Friday's high of 104°.If it were me and I was paying the light bills, I'd see how long the remaining (2) 40 watters will last.
