My IBA has an HP wax function. Normally it was 440psi. It had been getting lower lately and finally began pulsating.
I thought it was the solenoid valve that redirects some of the water back into the pump, so I changed that. The result is that the HP wax is now at 1050 psi, same as my normal HP passes.
I think I am on the right track with the solenoid. I did install one that I had on the shelf awhile so I think I should get a new one and see if the pressure on HP wax is more in my previous 'normal' range, right???
TIA!
TIA!
