DiamondWash
Is there a difference between the 2 styles as for the tip conversion chart they are the same in drill size and diameter
The blue educators from blendco have been modifed by blendco. What size tips do you have in your trifoam. How old are the hydrominders? Could they need to be rebuilt? Have you called your blendco distributor?I have 506/507 for style. What the difference between the Black, Blue, Brown educators? I currently have the black ones install for my s.s trifoam wax and it seems like too much water in the tank and there is no foam in the bay I just switched to Blendco chemicals as well, they use the blue educators on the other chemicals should I switch to blue for trifoam wax?
The color of the inductor helps determine the range of the dillution ratio. Here are some examples.I have 506/507 for style. What the difference between the Black, Blue, Brown educators? I currently have the black ones install for my s.s trifoam wax and it seems like too much water in the tank and there is no foam in the bay I just switched to Blendco chemicals as well, they use the blue educators on the other chemicals should I switch to blue for trifoam wax?
The brown one comes with the 515.Item #: CH511
Hydrominder, Low Volume w/ Siphon
·Siphon breaker included
·Eliminates the need for manually handling, measuring and mixing concentrated chemicals
·4.5 GPM @ 40 PSI
·Approximate Dilution Range Max: 240:1
·Approximate Dilution Range Min: 4:1
Item #: CH515
Hydrominder, Low Vol High Concentration
·1.5 GPM @ 40 PSI
·Approximate Dilution Range Max: 100:1
·Approximate Dilution Range Min: 1:1
We were at purple push in tips to start off with then moved up to brown tips and the color seems to be better but no shaving cream foam like before so I want to try to start over with a blue or brown educator with a purple tip in each color and see what happens.The blue educators from blendco have been modifed by blendco. What size tips do you have in your trifoam. How old are the hydrominders? Could they need to be rebuilt? Have you called your blendco distributor?
The Black eductor without a tip is 4:1. For both the 506 and the 511.I was just informed about the ratios with the different colored educators:
Black 4:1
Blue 3:1
Brown 2:1
Gray 1:1
The eductors with push-in tips have a different dilution chart than the screw-in type.DiamondWash said:We were at purple push in tips to start off with then moved up to brown tips and the color seems to be better but no shaving cream foam like before so I want to try to start over with a blue or brown educator with a purple tip in each color and see what happens.
Purple is way to small, one site i was at today that we sell blendco to i checked, we are running white blendco tips but he has very hard water and he likes real bright color and a lot of foam.We were at purple push in tips to start off with then moved up to brown tips and the color seems to be better but no shaving cream foam like before so I want to try to start over with a blue or brown educator with a purple tip in each color and see what happens.
To tell you the truth i have never asked if they are considered Ultra- Lean.Are the push in tips Blendco uses considered "Ultra-Lean" tips? what color educator was he using the Black or Blendco Blue?
