I have a Hydrominder (506 I believe) that stopped drawing chemical over the last few days. It's about 18 months old.
Foot valve, tip, and educator are not clogged. Water pressure is regulated to 45 psi. If I take the chemical tube off and put my finger over the opening, rather than suction I feel a weak pulsation, same if I remove the tip. I took the educator apart and cleaned it...no change.
The manual also says check for:
d. Discharge tube or flooding ring is missing. d. Check position: Replace discharge tube if flooding ring not in place.
The discharge tube is in place, is there something else I should be checking?
