HP pump plumbing
cleancars24
Hello guys,
I got this pump used and I'm wondering how this plumbing works. Soap and wax are gravity fed from a hydrominder tank, the bottom hose was city water pressure hot water in. What I want to know is when the wax or soap solenoids open do they get pulled into the pump along with the water in the bottom hose? So I'll need the mixture in the soap and wax tank fairly strong so it comes out the gun at the desired ratio, correct? I'm confused as to how this works with the city water pressure hot water, in my mind the pressurized hot water wouldn't allow the gravity fed soap/wax to enter. So should be gravity fed hot water?
Should I plumb my chemicals into the other side of the pump and leave the left side for just hot water?
What I want to achieve is hot water for all high pressure functions which is just rinse, soap and desalt.
Any advice is greatly appreciated.
Thank you
