bcwang
I encountered a SS bay that has a poster saying they use Ryko Rain-Shield. I thought this was normally for automatic washes, but thinking about it there shouldn't be anything wrong with applying it yourself at a SS. It's a bit strange to see there though, and I'm guessing the "power-gloss" setting should be the one that uses it, hopefully. However, I'm pretty sure there is a proper way to apply a surface sealant which automatics are probably normally setup to do for you.
So for those who know about Rain-Shield, what exactly is the recommended application procedure?
-how much to apply (thick or thin)?
-should I apply it to everything or avoid certain areas of the car?
-how long to let it linger?
-Rinse off with HP rinse or LP spot free?
-Should I avoid towel drying?
Thanks!
Thanks!
