M Matfry New member Joined Jul 30, 2016 Messages 27 Reaction score 3 Points 3 Location Fennimore, wi May 3, 2022 #1 Does anyone currently inject into underbody and how do you have it set up or is the only way to is using low pressure pump? thank you for any input
MEP001 Well-known member Joined Aug 30, 2007 Messages 16,667 Reaction score 3,937 Points 113 Location Texas May 3, 2022 #2 You can use a downstream injector but you lose about 20% of the pressure, otherwise you would have to introduce your chemical before the high pressure pump.
Roz Well-known member Joined Oct 29, 2017 Messages 1,235 Reaction score 652 Points 113 May 3, 2022 #3 Or buy a Washworld as their controller allows you to inject a chemical into the undercarriage
