I've had this problem happen a three times now over a couple of years The first two times on different pumps, I fixed it by replacing EVERYTHING (lines, regulators, solenoid valve, etc) because I have no idea how these actually work, and don't want down time. My first thought is it would be the solenoid valve, but I tried fixing that the first time and that didn't solve it.
So I thought this time since I can't order anything until Monday anyway, instead of just replacing each part, I'd get on here and ask which part is actually the one failing?
When High Pressure is on, I get high pressure out my low pressure presoak input hose. Its not "full" high pressure, but its enough to blow the plastic line.
(In the attached image, it is the RED line that breaks)
Bonus points if anyone can clarify how water actually flows through these lines. I looked at the diagram for the pump and it seems like there's water going in the out lines and out the in lines... I figured if I could figure out how they actually work, diagnosis would be common sense.
Thanks for the help!
