oznola38
From my understanding of the Water Wizard settings if I turn on "bug pass" (which is what gets the boom to drop twice) it will do it on both the front and back of the vehicle if the boom is set to drop for both. The work around would be if I have 2 HP rinse passes I could put the front drop only on one pass with the "bug pass" double drop, and no rear drop. Then on the next pass put both a front and rear boom drop with no bug pass. This would help shave off some time and should not hurt the wash quality.I think a lot of people are giving really good advice, but I will throw in mine.
Out of the few water wizards I have seen, i think they all have run the rocker pannel blasters on the second presoak pass. I like that you run tire and wheel cleaner too, thats especially good at removing bugs from what I have seen. I also really like that you do the extra hp passes on the front of the car. Keep that. I would say doing it on the back of the car is likely unnecessary though. Yes some cars get dusty on the back, but from what I have seen its seldom hard to get off.
Do you know what your tripple foam actually does? Our two older roll overs where special ordered at the time because the triple foam, served no purpose to the customer. The machines never had that equipment installed. It seems you are already running wax, so even if the tripple foam is a wax for you, from your chemical distributor, it may be pointless to run it and wax. That could save you 2 passes right their pending your situation. Or, if you want to keep the triple foam for the show, can you put it in at the same time as wax?
You may also be loosing time to your dryers, but that may be worth it for you.
Also, if it where me, especially in a cold climate, i would offer undercarriage on every wash. Costs nearly nothing, great benefit to the customer.
If you don’t sacrifice on your presoak, and wash pass speeds, i think wash quality should be great. I do think a minimum of two hp passes is good though. Sometimes our machine struggles to get all the soap off with just one pass. If you machine can though, more power to ya!
Our wash configuration:
Bronze: Presoak, wash, wash, SFR
Silver: Presoak, presoak, wash, wash, wash, SFR, dryers
Gold: Presoak, presoak, wash, wax, wash, SFR, dryers
Platinum: presoak, presoak, wash, wash, wash, wax, wash, SFR, dryers
One of our machines used to have onboard dryers like your water wizard, but they where removed because of the wear and tear they where doing to the arch and the wheels. Back then, the bronze was the same, but the silver was two wash passes instead of three, and one pass with the dryers. The gold and platnum where the same, but with two dryer passes.
On your lower wash you may be able to turn on the dryers at the end of the wash so the customers drive through on their own. I will say though, this will track more water out of the bay, so could cause ice issues pending how your wash is set up.
Hopefully that gives you a little insight.
The triple foam is McClean Foam Tricolor 200. The packaging gives me no indication about its function. Their website was no more help: "McClean's standard for high dye, high fragrance tricolor foam conditioning." I asked our chemical guy and he said its "technically a polish. It helps lower PH for better drying and adds shine". Not sure if if that is true - McClean's site makes it sound like its just color and fragrance.
If Foam Tricolor 200 and Clearcoat Protectant 100 will work together I could apply them simultaneously. It would have to be a back to front pass so that the clearcoat protectant is applied first (from the boom rain bar) and then the foam on top of it. Otherwise the foam would be rinsed off instantly. But this would leave my SPR going front to back so then would only leave 1 pass for the dryer. Unless I did a HP Rinse after the foam/clearcoat then SPR and the 2 dryer passes.
I'm concerned if we add undercarriage to all of the packages we will see more customers take the cheaper packages. I think through the winter a lot of people are most concerned with getting the salt off. They don't really care about the triple foam or clearcoat protectant - they will go with the least expensive option that gets most of the salt off.
I will have to play with the settings to see if I can run dryers on exit. Not sure I want to do that during the winter but could be an option during warm weather. We have heated concrete aprons but have had a little bit of water running off it creating ice.
