How are your sewer rates calculated?
Baywash
Mike
Southwest Missouri
I need some help! I just returned from the city council meeting for my town in which I have two car washes. They are proposing an across the board 30% sewer rate increase which would effect my bottom line dramatically. I stood up and suggested that this type of increase could not be entirely fair to industry in our fair city. I suggested that rather than implimenting flat rate increase, that it might be a better idea to use a sliding scale or business rate in order not to hender industrial growth. In my case, even though I use a lot of water, gallon for gallan, my water is much cleaner than the average household. Not to mention that all my solids are collected in my pits and the fact that I am pumping cleaner water into the sewer system actually helps the purification process.
My request to my fellow car wash operators is this.....what are different examples of how various townships calculate sewer bill. I have 30 days to formulate a proposal to my council for their consideration. I do not feel I should pay the same rate (meaning lower) as the average household which has the higher BOD count in their waste water. If you don't have any particular formular, I would be interested in any ideas, suggestions, brainstorms, etc.
Thank you,
Mike
PaulLovesJamie
rural 5 bay SS
Kutztown PA
Mine are straightforward: gallons of water used times sewer rate. I actually pay more for sewer than I do for the water. I'm not happy about it, but they dont care.
Dean Taylor
Dean Taylor, CATEC.com
Sarasota, Florida
Almost all sewer fees are calculated from the actual amount of water used. This is unfair to car washes because there are water losses at a car wash that do not go to sewer.
The same holds true with residential too. If you irrigate your lawn or fill a swimming pool, you haven't put that water to sewer, but you still have to pay for sewer.
They do it this way because it's quick and easy and they only have to read one meter to get both fees. Most municipalities won't even discuss a separate meter for sewer.
The best measure you can take to combat these increasing fees is to recycle your water. You can expect up to 70% savings in water and sewer rates if you employ a good reclaim system. It can also make you immune to drought closures like the ones going on in the Atlanta area right now. How would you like to hear "No reclaim, sorry, you're closed!" ? It's happening as I type.....
For those that think recycling water isn't for you, you might want to wake up and smell the coffee. Recycling water is fast becoming a necessity to even be in the car wash business, both economically and through legislation.
PaulLovesJamie
rural 5 bay SS
Kutztown PA
Dean, good info, most of it is correct ...
But I have to say it - I doubt that anybody disagrees that water recycling is a good idea. Here's my problem with recycling: it will cause me to lose $. Probably a lot. I'd bet that the vast majority of small businesses (including self service car washes) are in that boat.
Rather than insult our intelligence with "wake up and smell the coffee," how about giving us an honest cradle-to-grave business case indicating that it is a wise business decision? Post it up on your website. And please let me know when its there, because the honest truth is that I personally would LOVE to put in water recycling at my sscw. Prove that it will make my sscw more profitable within a reasonable time period and I'll probably buy one. Every large company I work at makes business decisions based on a spreadsheet, not words. Show me the numbers!
Sorry, I dont want to hijack this thread, I just couldnt let that one go.
Mike, this topic has been discussed quite a bit in the past - check the old forum archives, theres quite a bit of info out there. Also contact Jarret at the SSCWN for a reprint of his articles on this topic. A few of us (not me) have been able too get sewer rates reduced, but unfortunately I'm not optimistic for your chances.
Also, be sure to raise your prices, and be sure to advertise very clearly why.
Baywash
Mike
Southwest Missouri
Paul,
Thank you for your comments and suggestions. I actually think I have a shot at getting special use rates as I am in pretty good with the city. I was hoping someone had similar situation were a township has a formula for special use operations. I will look a little harder for the mentioned threads. I have already recently raised my prices across the board at my two locations and have certianly not regretted it.
The comments on water reclaim was a little harsh. I agree with you Paul that it could posibly not be for all situations. Don't think for one minute that I did not run the numbers when considering water reclemation. For the most recent location I built, the numbers just did not ad up. If the truth be known, my water/sewer rates are very resonable and it would have been a money loosing proposition to install water reclaim. Even with the 30% sewer rate increase I am facing, the numbers still would not support water reclaim (unless something has changed in the last year or so). The time will come when I will do it if for no other reason other than it is a good thing to do. The last thing I need is for someone to tell me to wake up because I don't know what I'm doing. A better approach would be to refer me to a website that could explain to me how installing water reclaim system can make/save me money (catastrophic drought asside).
I would like to say that I have read the posts and magazine articles about the Atlanta situation. My sympathy goes out to those owners facing finacial difficulties and kudos to the guys already recycling their water.
Mike
Dean Taylor
Sarasota, Florida
Hi Guys,
I'm sorry if my post seemed a little abrasive, I certainly didn't intended it to be.
You guys are absolutely correct is saying every wash doesn't need a reclaim system, especially SS bays. There are many areas where water and sewer rates would never justify recycling water. When prospects call me, one of the first things we discuss is their water and sewer rates. If it can't be financially justified with a reasonable ROI, I let them know right up front.
The point I was trying to convey is, with droughts and the push for "Green Buildings", you will see that legislation is driving in the industry in this direction. Not only with car washes but with many, many other businesses as well.
I have quite a few clients that have invested in reclaim systems simply because they felt it was their moral obligation to recycle water. Many others have to have reclaim systems to get permitting, as recycling is already mandated in many areas.
Similar to no smoking laws, it is a gradual process that, in time, will end up affecting car washes across the board.
I hope this doesn't come across as too bold, I feel it's the truth.
PaulLovesJamie
rural 5 bay SS
Kutztown PA
Ahhh, sorry guys, I really didnt mean to be harsh either, but yeah, re-reading my post maybe I was. Sorry. Believe it or not, I was actually trying to be constructive, I did not intend to offend. It's bow season, I'm probably just not getting enough sleep.
Dean Taylor
Sarasota, Florida
No problem Paul, good debate is actually quite healthy. Sometimes online, things are read in a different context than they are typed.
To answer your question, typically a reclaim system can be justified when water and sewer bills exceed $ 1,000.00 a month. 70% reduction of water and sewer is typical, resulting in a $700.00 a month savings.
This is interesting:
A fellow called me yesterday from a severe drought area. He is in process and has actually broken ground on a 4 bay SS. He wasn't going to have a reclaim system because he couldn't justify it in savings. His lender shut down his project (the money to fund it) until he could prove he was installing a reclaim system to prevent drought closures.
Actually this was pretty clever thinking of the lender. Why would they lend money to a project that can't even open the doors? The lender has agreed to fund the reclaim system too. The project is back on track today.
Chiefs
Recycling water at the conveyor and In-bay automatic is infinitley easier and the payback far greater than it is for the self-serve operator. At the self-serve people are not just merely washing their vehicles. The are dumping their RV toilets, cleaning horse trailers and changing their oil. This is also a red-herring for the self-serve operator as the amount of fresh water used to wash and rinse at a self-serve wash is far less than the amount of fresh water used per car by a tunnel or in-bay even if they do recycle 70-80% of their water already!
A self-serve wash on fresh water is the best way to conserve water.
Baywash
Mike
Southwest Missouri
It is apparent that we would rather talk about conserving water rather than figuring out how to keep my rates low. OK, I'll go with the flow (pun intended). After all, I see this as a means to a long term end to high water bills and even though my neighborhood is not all that "green", I could start educating my customers on how environmentally friendly my wash is. After being in operation for 20 months now, my water bill is typically over $1000 per month. I have four HB and two IBA. One unit is frinction using around 50 gals. per wash and the other uses 100 gal per wash. I pay for around 200k-300k of water/sewer monthly. Send me the numbers, web sites, etc....and I will revisit the reclaim issue. Feel free to contact me on private post is that is possible here.;)
Baywash
Mike
Southwest Missouri
One more quick note....I would like to hear from anyone who has installed water reclaim after the initial construction of the wash. Pros vs. Cons, cost savings, regrets, customer reaction, ROI, etc.
Also, this origial question about sewer calculations is still the main topic and I am still interested in any feedback.
thanks
How much will the supposed 30% increase in sewer charges cost you? No more than $200/month is my guess. be sure and factor in the cost of the unit, the electricity used by the reclaim unit, the (slight) increased wear on the pumps the possible need to change your cleaning chemistry to more expensive reclaim-friendly products and more wall/ equipment cleaning in your cost evaluation. In my area, for every reclaim that is running at an operator site, there are two turned off.
Seriosuly, I can get you a heck of a deal on a "slightly used" system with only a couple hundred hours on it if you interested in one.
rph9168
Carwashguy
Atlanta
In the Atlanta area you cannot remain open unless you have a reclaim system so I think that may be another reason to have one. It may keep you open in a drought or under stricter government regulations.
Baywash
Mike
Southwest Missouri
Greg,
I believe what you say about having the units istalled, but not using them. I am going to have another look at the install and ROI. My guess would be that a used system would be the way for me to go. I like plan B's and options. I bet after running the system, I would be one of those that installs by-pass valves around the unit. We have in the past been through periods when our water table gets low, but never to the point of manditory water conservation.
By-the-way, you are correct in your increase of cost guesstimate for my sewer rates.
thanks
The two go hand in hand, unless you're willing to go and fight to have them lower your rates. Since your sewer rates are directly related to water consumption, conserving water is your only other option.
Baywash
Mike
Southwest Missouri
Talking to the city administrators about special use sewer rate was the original topic of this tread. My city is in the process of adjusting the rate, and have ask for public input. My original question was just that, "how do I fight for lower rates," and has anyone on this forum done so?
Now we seem to be talking about water reclaim....which is fine by me as I am now thinking about it.
Some cities sewer rates have nothing to do with sewer useage although you may need to press them to admit it. If your city indeed has special rates to account for use that is not discharged consider yourself lucky.
If the sewer rate is really just a revenue raising device with a misleading name because it is really a water useage tax instead of a sewer useage fee, then stop wasting your time and energy trying to convince them you should get a special rate.
Have they given special rates to any other users?
pitzerwm
Tri-Cities, WA
If there is a possibility of a reduced rate on actual use. Get a sewer meter and show them the difference between water in vs water out. Done deal.
AdamA
Bend, Oregon
My rates are calculated water x rate = bill...
However, they use a winter uses multiplier where the sewer rates are based on your usage for three winter months. Meant to not charge you sewer for irrigation water. Since winters are slower for me I come out ahead. Might be worth suggesting, especially if your winters are slower and you have significant irrigation usage.
washnvac
Seaford, DE
One of my municipalities let me put in a sewer meter, so I only pay what goes to the sewer. It is the ultrasonic kind which reads throught the pipe--nothing to get caught in an impeller. Caution though, be sure your guttering is clearly directed away from your building and drains. As well, I corked the outside manhole covers to the settling tanks. My sewer usage is 10-12% less than incoming water gallonage.
