Hotsy to Clean Bay Walls
DPD36
I've been looking at buying a Hotsy hot water pressure washer for some projects around the house/shop. Was curious if anyone has ever used one to clean PVC panels in an IBA. Our current practice in the IBAs is to use a low PH presoak and run a wand off an adjacent bay. Wondering if the Hotsy would work to clean panels without having to mess with spraying presoak and help me justify buying something that I probably don't really need.
Car_Wash_Guy
out west
I built a monster HW pressure washer trailer. 47hp Twin Kohler, gear driven pump and hot box. 10gpm at 3500psi and 180 degrees. Still doesn't clean the walls anywhere near as good nor fast as using SA
Rfreeman
Ft. Worth
I have 3 hotsy washer for my other job. Unfortunately never used just hit water to clean bay walls always with acid....with acid and the hotsy it does the job though.
You might try renting one first? I've often wondered the same thing about using one...My PVC walls are about due again!
Car_Wash_Guy
out west
I wouldn't waste your time.
The HW washer is great for the concrete with either Gold Assassin or SH
kentadel
Nebraska
I apply A.P. Formulator's Clean Wall, let it soak for a minute or 2, and follow with my bay gun. Works great. If you go without cleaning for a year or 2 like I did at a location you may need to hit it twice or even scrub it a bit.
Be careful when using the A.P. Formulator's Clean Wall it's some pretty dangerous stuff. file:///D:/Users/eagle/Downloads/Klean%20Wall%20SDS%202018.pdf it's best to wear rain gear, rubber gloves when using it.
