I was thinking about rinsing with cold water instead of hot. I talked to one owner and he has multiple washes that he rinses in cold during the winter at all and says it works fine. Does anyone else out there do this? I would imagine the savings would be pretty good!
If you dont use hot water i would expect you to have a low low price or I would wash else where, just my thoughts, we heat all our water, rins hp and customers do notice. We do have on-demand heaters tho.
I use hot water all winter long, but in the evenings I use an intermatic timer to shut my boiler down between 9p-6a and I realized a decent savings there. Not to change the subject, but I also don't weep hot water. With heat tape in the trough, there is no reason to and I have yet to be convinced of that.
Hot rinse water? I don't understand what the advantage of hot rinse over cold rinse. Hot water with soap makes sense for it helps clean a lot better, but for rinse, all your doing is washing off the soap.
I'm hot for everything except for rinse and spot free rinse. Those two items are cold. Yes, you would see savings if you changed to cold rinse and wouldn't impact the cleanliness of the cars.
You’ve got t o be kidding me!!! HOT WATER RINSE! Are you washing cars or dishes? Up here in the Pacific Northwest we only heat the Presoak. Rinsing with hot water doesn’t do anything to aid in washing the car, just my 28 year in the business opinion.
None S/S car washes here use Hot water for rinse or wax. I know of a few that don't have any Hot water and they do just as well as the S/S that do have Hot water.
I agree. My SS pump stand was set up that way (hot water everything HP) and I plan to change it. I can mix hot and cold and definitely do throttle back on the hot as much as possible.
There is one possible benefit of a hot rinse in an IBA or tunnel. Drying agents and sealants do not work well or even at all when it is very cold out. If you are concerned on how dry the car is after the wash and it is very cold out you might consider a warm or hot water rinse depending on your use of hot water in other applications in your wash. If you feel that the ambient temperature of the vehicle's surface is at least 50 degrees when it the sealant or drying agent is applied you are probably okay. If not, a hot rinse could significantly help drying.
