I'm considering a coin operated tire inflator and want to make my own...I searched old threads and there's not much on the subject...The coin box, timer and coin acceptor is the easy part....If anyone has made their own, maybe you could share your thoughts/experiences...Even with the commercial ones, you might have suggestions and comments to offer.
A Few Questions that come to mind...
What solenoid did you use? Most solenoids require a differential between inlet and outlet for the solenoid to work properly. Since air will be deadheaded at the tire chuck, is this an issue?
I'm also trying to figure out what hose is best to use? A coiled hose and a hook on the wall below the coin box to hang up? Or a straight 1/4" or 3/8" hose? I'm also considering an automatic reel but I am limited to having it mounted on the side of the building under the coin box. I can't mount it so its inside my ER....I can see a lot of reasons NOT to go this route....A lot of the commercial air machines at gas stations back here use 1/4" coiled hose. Even though I mostly see them in knots! It probably won't be any worse than vac hoses, just one more thing to add to the list of things to do at the wash!
So Decisions, Decisions...I have an 80 gallon compressor that I rarely hear come on so I have plenty of capacity. I can't see spending several grand on a commercial air machine but would be nice to have another income source. I can do this for about $500 or less using my existing compressor...Thoughts/Suggestions?
