traveler17
I was asking if he wanted to build some for mehow much per unit ? I may need a few....
I understand. I was asking for me.I was asking if he wanted to build some for me![]()
What’s your addressOk first one to send a stripper to my house gets priority!![]()
What did you use for a boom in the bay?I built 14 of these attic mount for my locations. Hope this helps.
Bada a $300 boom too! I'm defiantly going this route.Diskin air shammee boom.
Is that for the input or output?Highly recommend a Boom Elbow. https://www.kleen-ritecorp.com/p-45743-mosmatic-902-119-air-boom-clean-out-elbow-2-inch.aspx
Exit - Otherwise hose attaches Horizontally and turns down putting stress at turn and it cuts or breaks.Is that for the input or output?
GOOD question. The ones I bought had one end larger so it slipped over end of boom and larger end had a slit and cutout so you could squeeze it with large hose clamp and / or secure with self tapping screws. The photo for this one does not have that . I suggest calling KR to confirm or maybe Diskin.How do you attach that? Does it slip over the end of the boom?
https://www.airlogicwashsystems.com/shop/p/air-logic-dryer-nozzleWhat are you guys using for handles? Reading bad reviews on the Air Shammee handles on KR.
Those things are pricey, at least you are able to salvage more life out of damaged onesAnd when someone leaves it on the ground and it gets run over by a car, usually part of the tip breaks off. I just take a hacksaw and cut the broken part off and sand the edges smooth and keep using it.
They look like they have a really small nozzle compared to the Air Logic. The first Air Logic gun we bought was awesome, but then we bought three more, and they had the truck bedliner sprayed on them inconsistently. The coating inside the hole was thicker on one side, and overall, the hole was larger, so they didn't have the impact like the first one we bought. We were not as impressed, but we are still using them.I switched from air shammee to premier and what a difference. The flow is so much stronger. Customers love them and they are a 1/3 of the price of air shamme and air logic. For $38 a piece I keep at least 3 extras at each location just to have in stock incase one gets ran over or abused.
