Home built air dryer.
They look like they have a really small nozzle compared to the Air Logic. The first Air Logic gun we bought was awesome, but then we bought three more, and they had the truck bedliner sprayed on them inconsistently. The coating inside the hole was thicker on one side, and overall, the hole was larger, so they didn't have the impact like the first one we bought. We were not as impressed, but we are still using them.
Yup, one of ours started to detach on the inside and it sounded like the world's largest balloon was deflating. Still using them tho. I noticed KR still has them listed in their latest catalog but they don't show up on the website.
I switched from air shammee to premier and what a difference. The flow is so much stronger. Customers love them and they are a 1/3 of the price of air shamme and air logic. For $38 a piece I keep at least 3 extras at each location just to have in stock incase one gets ran over or abused.
Link?🙏
The premier guns have a fan nozzle. Ive never used an air logic one but when I first installed the dryers I had just the regular air shammee nozzles that was maybe a 1 1/2" open hole and they were terrible. I ended up buying the fan nozzle for them a few days later and it helped a lot but that fan nozzle breaks easily and is $40 by it self. A TON of air gets lost though in the air shammee guns. Never realized exactly how much until I tried a premier one. You do have to buy a premier wall mount for them but it's probably the best made wall mount bracket ive seen. Ive switched a good amount of customers over to them.
Edredtop I do not have a link for you. Premier works on a distributor network. Here's a few photos though.
If any of you guys are interested let name know and I can send you one to try out. You won’t be disappointed.
Had air shamee nozzle break and did not have a spare. I used one of my Cheap Vac Claws - Worked amazingly well. Repaired the Diskin Nozzle but I may just use the claws.
Now that you mention that which ive had to do before. The crevice claws nozzle from mr nozzle would probably do a great job. It has the same fan type nozzle as the premier gun dryers and will fit in their nozzle holders perfectly. Not as solidly built at all but would work good in a pinch.
