You can most likely eliminate the High Velocity UCC by swapping out relay 1200 for entrance
door up and inspecting the wires on terminated on the relay. The relays for the
door controls are used as a set of dry contacts, if the relay isn't working properly or if there is a loose wire on one of the terminals it could interrupt the the
door going up. Other than that it may be a connection on the
door controller itself.
