High pressure soap
Jojim361
Why won't my high pressure soap come out? I've already changed the grey tip that goes into chemical as well as portion tip. It also seems like there is air in the lines/loses pressure but only on high pressure soap. Any advice would be great. Thank you.
Ryancross11
All bays? Are you getting soap to your solenoids? ( disconnect your tubing at the inlet side side and see if it flows out.) I have a screen/ filter at the bottom of my tank (that goes to the solenoids)that gets gummed up and needs cleaning.
Jojim361
I didn't check all bays but I check 2 out of 4. I will try and look at what your talking about tomorrow
Post some pictures. It sounds like you might be using tubing fittings from the tank through the solenoids and to the pumps, and there's an air leak in some of the fittings.
Jojim361
I will try and get to it tomorrow. I'm kinda out on leave due to my wife having a baby 🙂. Will definitely take pics asap. Thank you
