Help with what Hydrominder
OASIS WASH
jacksonville
Bought my first self serve wash 10 months ago. I don't have a problem with any hydrominder's but I am starting to buy replacement parts for different items for when I do. I cant post pictures on here but I can send them via email. Looking for someone to help me size which hydrominders I need. Right now I have Dema's that are probably 10+ years old.
Thanks so much!!
Why can't you post photos on here? It is much easier that it used to be.
Thanks so much!!
506 / 511 Hydrominder depending on whether you want the anti siphon. Keep one spare and few of the IN665K repair kits from Kleen rite. If one in operation needs a rebuild put on the spare, re build bad one and use the rebuild for the spare.
Can you explain to me what the anit-siphon does and why I would want or not want it? Thanks!
It keeps the diluted chemical from the mixed tank from siphoning back into your drum of concentrate in the event the foot valve fails. I would use the 506/507 and just make sure that there is a hole in the discharge hose, below the restrictor in the hose and above the water level in the mixed tank. The 511 has a siphon breaker on the valve, which is a bunch of unnecessary parts that also make servicing it a little more trouble.
