O OASIS WASH Member Joined Jun 25, 2018 Messages 77 Reaction score 16 Points 8 Location jacksonville Nov 13, 2019 #1 I need to replace this KIP solenoid block. How do I know if its metering or less metering, and what does that even mean?
OurTown Well-known member Joined Nov 8, 2017 Messages 3,363 Reaction score 1,221 Points 113 Location Ohio Nov 13, 2019 #2 It means it has an adjustment screw for throttling back the output for fine tuning.
O OASIS WASH Member Joined Jun 25, 2018 Messages 77 Reaction score 16 Points 8 Location jacksonville Nov 13, 2019 #3 Oh gotcha...can you tell if that is one? Where would the adjustment screws be located? THanks.
OurTown Well-known member Joined Nov 8, 2017 Messages 3,363 Reaction score 1,221 Points 113 Location Ohio Nov 13, 2019 #4 Somewhere there should be a small set screw for each output but I can't tell from the photo.
OurTown Well-known member Joined Nov 8, 2017 Messages 3,363 Reaction score 1,221 Points 113 Location Ohio Nov 13, 2019 #5 They may be on the other side.
C Car_Wash_Guy Well-known member Joined Apr 6, 2015 Messages 1,140 Reaction score 322 Points 83 Location out west Nov 13, 2019 #6 I just replaced one on my dog wash. There should be a small metering screw either on the right or left hand side right adjacent to the in/out
MEP001 Well-known member Joined Aug 30, 2007 Messages 16,667 Reaction score 3,937 Points 113 Location Texas Nov 14, 2019 #7 You can't see the adjustments in either your image or the one I linked. They're on the opposite side of the "OUT" port, just a screw head sticking out.
E Earl Weiss Well-known member Joined Aug 31, 2007 Messages 6,225 Reaction score 807 Points 113 Nov 14, 2019 #8 Metering is to adjust the output. Some on the forum use this feature. I do not. I regulate output by the air pressure of the pump feeding the block.
