Hardwired air compressor
traveler17
SE NC
The new location I just required has the compressor hardwired to the breaker box. I’ve had a couple locations in the past and haven’t seen this.
Question is this a normal setup for most or some of you guys? Any pros or cons to this? Change it up or let it ride?
thanks for the feedback
Toms PTcarwash
Landisville, Pennsylvania
It's not a problem having it hard wired, so long as you have access to the breaker.
Not like you would be unplugging it on a regular basis for any reason is there?
traveler17
SE NC
No sir, never unplug it. Just for reasons for if/when it goes out. I just had never seen this and wanted to make sure it’s good to leave it that way. Thanks !
240V compressors usually come with no plug, so they usually end up getting hard-wired when they're installed. TBH I'd rather have something as big as a 7.5 HP motor hard-wired than plugged in, or I'd use an extra-heavy plug and commercial grade outlet.
