Gs 101 vac timer
jrecchi
downingtown, pa.
Ineed to get a new vac timer for one of my vacs.It currently uses a GS-101. Since they are not available any longer,can anyone tell what the current equivalent timer model would be?
Thanks
Dan kamsickas
GinSan Technician
Grand Rapids, MI
Thanks
The replacement is a GS403. The technical sheet has a wiring diagram that shows how to wire it when you are replacing a GS101.
We’ve been using the $38.99 KR #TIKR540 Vac Timer with good results. You always want to install a Mercury relay on the load side of the Timer. This will prolong the life of the Timer and prevent the Timer from being damaged should a motor short out.
