GPM requirements for well
guitarandy
Vidor, Texas
I am looking into drilling a well for a 1 IBA 4 SS wash. Has anyone researched how many GPM that would be required for this application? I know that Waxman has been talking about drilling at his site.
easywash
Well GPM
As long as you are getting a couple of GPM and you have a large enough holding tank for your on demand water you should be ok.
It's probably best to get the help of an engineer/your distributor with that calculation.
Hope that helps a little.
guitarandy
Vidor, Texas
Thanks Easywash, my distributor finally got back to me with the numbers. The IBA has a 38 GPM pump, the SS are 4 GPM per unit, and the RO is 5 GPM.This is the maximum usage.
bonanza1
brunswick georgia
i have been running a 2iba and 4ss for about 11 years, 3hp pump deep well buisy location no problems.
borumrm
TN D&S 5000's
TN
I would be interesed in knowing how this is set up. Where is your storage tank for the well water, how large, how do you force it thru a softner system etc. to ensure adequete pressure? My property used to be a small house with a well a long time ago but the well is long gone although I think it could be reborn...if there is a drought how does it tie in with city water system to ensure supply...
Dean Taylor
Dean Taylor, CATEC.com
Sarasota, Florida
Your full up and running demand is about 50 GPM. While a holding tank will help to keep up with demand, a good reclaim system could lower your demand to about 15 GPM as well as lowering your discharge by about 80%. The upfront investment will certainly be more but the advantages may very well be worth it. It's something to ponder anyways.
