gould pump replacement for sfr
cmawash
camarillo calif.
not happy with pump life span for Gould pumps, use 1.5 hp units with200 psi sfr, unit in bays , one unit was just replaced lasted 3 years before booster pump started losing out put pressure to car wash bays, any recommendations for a replacement pump, realize Gould pump is cheapest way to boost pressure but looking for longer life span any comments on procon series 6 pumps
Curious: Are you unloading/bypassing properly to allow the pump to circulate adequate flow while running?
Keno
How much flow do you need at 200psi?
I have been replacing my puck style pumps with centrifical pumps of the same horse power and been very happy with the results. No more replacing the booster pumps all the time.
