I have a new mark vii jet wash for my ss. They are currently wired to ginsan gs402 timers. About two weeks ago one of my bays started having a weird issue were sometimes it would take 6 quarters take quarters to start (as it is suppose to) sometimes 7 quarters,8,9 and sometimes more! I figured it was a timer issue so I switched it with another bay that was working just to make sure.. nope! The issue continued. The mark vii jet wash has a coin pulse button on the pump stand so I removed my slug buster acceptor (now thinking that it was the problem) and pressed the coin pulse button.. but the issue was still there. Then I put a voltage meter on the timer terminal 1 and 4 to check to see if there were 24 volts (which there was). But when I did this and pressed the coin pulse button with my meter still on the timer I never had an issue. It would start on 6 quarters every time. Then i removed my voltage meter and the problem came right back. It would also work if I went from the #4 terminal to ground. To make matters worse two days ago another bay started having the exact same issue…
pictures attached are of the inside of the pump stand
