ginsan gs-16d - wiring
mcwashes
I'm trying to clean up a mess of a pump stand from when vandals broke in and indiscriminately cut wires. Luckily there was enough slack in the wires coming from the bays for me to get the wires connected for part of the system. However, I'm not getting any power to my meter boxes because I'm still missing a few main connections. Right now I'm looking for any wiring diagram for the ginsan gs-16d multiplex control with delay.
@Dan kamsickas - you sent me a diagram a while back for the whole system and it's been super helpful. I have some LED 9's in the shopping cart to replace the GS-401 timers. Any advice there (aside from just throwing the whole system in the trash - I know this is your preferred approach lol).
The wiring diagram I have helps me a bit but the installer definitely didn't wire it exactly that way. Luckily there are 2 bays that were not cut up in the box, but all the wires going to solenoids were cut under the box making it impossible for me to know what terminals on the bar go where. I have some installers coming, but I'm trying to knock out as much as I can.
Thanks
I've reconnected the wiring coming from the bay to the bottom of those bars for each of the 3 bays. I reconnected the 3 phase power to each, and I've been able to get the transformers all reconnected. Main issue now is knowing where all the 2-wire (grey sleeve with black and red) get connected. Some run to solenoids, some are carrying power it look like, but all are cut under the control box making it impossible for me to figure out which terminal they should go to on the wire bars...
Those appear to be the control wires to all the function solenoids. Unfortunately, you're going to have to physically trace them back to the solenoids.
