Our pumps are plumbed where gravity fed water comes in on the left side inlet and our chemical solutions come in on the right side inlet after passing through a solenoid. I wonder how this affects the dilution as the pump pulls both solution from both inlets and how i might get a stronger solution without changing the tip on the hydrominder. current hose size for the water inlet is 1/2in and hose size for chemical solution is 1/4in. TECHNICALLY CAT PUMPS RECOMMENDS A HOSE SIZE HIGHER ON THE INLET PORT AND THEY RECOMENNED NO HARD PIPING. However my question remains if enlarging my hose size is the best move to increase chemical strength and show for the hp
soap and wax without changing the tip size. I'm already diluted so high that the foam brush stains my walls just to get the foaming action that i like.
